Nesting in NX
I search software Nesting in NX.
does anyone know a liogiciel?
Thanks.
Emmanuel.
http://www.janus-engineering.fr/
Re: Nesting in NX
Builder
Builder
In NX, you can use loop in NX expression as follows.
It can return any NX expression types. This example I'm returning list. Make sure to set return type as list from the drop down list on Expression dialog box.
exp1 = loop{for $f from 1 to 5; collect 10 + $f;}
In this example looping count 5, adding 10 with incremented value and stored it as list.
ECR
PradeepECR
NX7.5 TC8/ NX9.0.2.5 TC10.2
Re: Nesting in NX
Esteemed Contributor
What kind of nesting are you talking about?
Nesting sheet metal parts to maximize the usage of a blank sheet of steel?
Something else?
Re: Nesting in NX
Hello Ken,
it is to perform nesting of mechanical part but flat. The parts can be different.
Emmanuel.
Re: Nesting in NX
Are you looking for this?
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
Re: Nesting in NX
Many-many years ago, at last century, on the UNIX workstations , Unigraphics has application Nesting, from third party developers. But - after Windows migration this application diappear..
Re: Nesting in NX
itis a pity not to have maintained this function because it is useful for many applications.
I hope that someone will read SIEMENS home ticket and request an ER :-)
Thanks.
