New Comman in NX 10
Dear all,
I use NX 8,5 and use Instance Geometry Command the same picture.
 But when i using NX 10 version , i don't find this command . Please help me and learn this change 12.png
Re: New Comman in NX 10
It was updated in NX 9.0 to Pattern Geometry Here is link to the what's new: https://support.industrysoftware.automation.siemens.com/docs/nx/nx9/wn/index.html#uid:index_xid29307... Scott
When looking for a command, try the command finder in the top menu area. In addition to the actual command names, it also searches based on common terminology and synonyms.
In this case, entering "instance" would show you the Pattern commands.
Mark Rief
Retired Siemens
