07-13-2017 05:30 PM
Have you tried to import those NX exported DXF files? For me, it gives an error message and fail to open. NX DXF/DWG import wiz’s Preview window shows the view but it doesn't open. I could open with E-drawings (Free application).
I don't know if I'm doing anything wrong with those many settings.
Please check the attached exported DXF file. Machinist needs my drawing in DXF format with dimension origin coincide with absolute zero. How would you do this?
In earlier versions, I 2d export IGES and moved the objects and then saved as DXF. With the new NX, there is a message saying that 2d Export function has moved to DXF/DWG Export Wizard. Does anybody know how to use new DWG/DXF export/import wizard to get the results I need?
07-13-2017 07:03 PM
Not sure about an export issue, but your DXF imports just fine with no settings changes.
Attached should be a video showing what I did.
07-14-2017 08:23 AM
Hmm....
Second video isn't available to view (Is it only for me?)
Could you please share your import settings?
07-14-2017 08:30 AM
07-14-2017 08:36 AM - edited 07-14-2017 08:41 AM
Hmm....
First, I tried to OPEN the DXF file for many times with different settings and then IMPORT to a new MODEL and DRAWING part.
07-14-2017 08:46 AM
I should contact GTAC and go trough my default setiings. I think they are messedup.
Have you tried to just FILE>OPEN>( *.DXF FILETYPE)?
@PhoeNX_Support Thanks for confirming that you could iMPORT the file without an issue.
07-14-2017 08:50 AM
I have no problem to open the file you have provided with either File > Open or File > Import > AutoCAD DXF/DWG.
Ganesh
#IngenuityIsNX | NX - What's New
