No tool mark symbol
Master
Master
I cannot seem to find the no tool mark symbol. V with angled line through it. Anyone know where that is? Thanks
Shags72 Mfg. Eng.
Windows 10 Pro 64bit
NX 11.0.2.7 MP2 Teamcenter 11
Dell M7720 i7-6820HQ 16GB RAM,
NVIDIA Quadro P3000
Re: No tool mark symbol
Can you provide a sample of this symbol?
How is "no tooling marks" different than a surface finish symbol with the "P" lay symbol?
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Master
Master
NO TOOL MARK.jpgI guess I should have said no tool drag.
Shags72 Mfg. Eng.
NVIDIA Quadro P3000
Not familiar with that one, nor do I see it in ASME y14.36.
-Dave
Here's a list of characters that can be inserted using control characters or utility symbols (your drag symbol is not listed):
Symbols generated using Control Characters
Symbols generated using User Defined Symbols
If this is a common symbol that you use, your best bet is to create a new custom symbol.
If this was originally created as a custom symbol, and you lost it after an NX upgrade, it's possible that your custom sbf file was not migrated to the new NX version.
Regards, Ben
Master
Master
Thank you both for your replies. I will have to create my own.
Shags72 Mfg. Eng.
NVIDIA Quadro P3000
