Number of sheets incorrect
Honored Contributor
Honored Contributor
NX 9.0.3.4 mp3
Has anyone when using:
<W@$SH_SHEET_NUMBER> OF <W@$SH_NUMBER_OF_SHEETS>
that the number of sheets will increase by 1, randomly?  A coworker pointed out that his drawing said "1 OF 2", when he only had one sheet.  Then I created a new drawing, and it did the same thing.  Note, this is using master model.  I started to make a test file, to send to GTAC, and it was fine, I went back to my original file, and it too was correct.  I added some views, a parts list, etc., and noticed it was back to "1 OF 2" again.  Then I ran a part cleanup, and it corrected itself, but I still wonder what is triggering this.
Anyoen seen this before?  I'd report it to GTAC, but I'm at a loss right now, on how to reproduce/demonstrate it.
-Dave
NX1867(if it had versions) | Teamcenter 11.6 | Windows 10
8 REPLIES 8
Re: Number of sheets incorrect
I have this too and I can't say what's triggering it. It's been there since V8.5. I see it in my title block.
Funny part about this; when I make a plot or a PDF export, it will show the correct number of pages. But on the screen it will still show e.g. "1 of 2". Only after closing the file and reopening it, the number of sheets will be shown correct on the screen.
Huysmans Metalen n.v.
2x NX1867 Mach Designer
on Win10 64bit
NX Beta Tester with focus on Sheet Metal
Command Finder is your friend
Do you have a parts list on your drawing?  If so there is an issue with GTAC on this.  I have been having the same issue in NX8.5
Honored Contributor
Honored Contributor
I do believe it did have a parts list.
I found the existing IR 8252196
-Dave
Honored Contributor
Honored Contributor
I spoke with my coworker that first noticed the issue, and his part was NOT an assembly, and did not have a parts list.  Mine did.
-Dave
Cool!
This will be SO much fun to explain to users :-(
No Parts List here.
on Win10 64bit
I have seen it also. NX8.5.3.
Don't think it was an assembly.
Builder
Builder
After create view with option "Orient View Tool" number of sheets is increase +1.
