Nx 11 Automation Designer
Builder
Builder
Dear All,
What's the new application tab called Automation Designer about?
Why there is no documentation for this new application?
Sina Shojaee
3 REPLIES 3
Re: Nx 11 Automation Designer
Siemens Genius Siemens Genius
Siemens Genius
Automation Designer is a new product which will be available commercially to all customers with NX 12. For NX 11 it is controlled by an environment variable for use by early adopters via the product manager.  There is initial Automation Designer help available as well for early adopters via a controlled URL.
NX Design Apps Documentation & Courseware Manager
Builder
Builder
Thank you,
And how will Automation Designer help users?
Sina Shojaee
Siemens Genius
Automation Designer is a Digital Factory solution for electrical and automation engineering. It lets you design the electrical and automation solution for a production system or machine, eventually enabling the generation of its electrical schematics and PLC program. Can also work with other automation products like Line Designer.
