Oblong hole
What is the fastest way of doing this kind of feature?
3 REPLIES 3
Re: Oblong hole
Ciao,
there is a very old feature called Slot
Ciao
Re: Oblong hole
Go to Reuse Library, It's available under 2D Section Library but with different name. You can change the dimensions as you needed.
Ganesh Kadole
Re: Oblong hole
you can also create your own reusable object that subtract the slot shape from your model.
see in the reuse library the snap example how you can doe that.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
