Offset curve always overdimensioned
When in sketch mode, almost every time I try to use "offset curve," the operation will complete, but the curve will immediately turn grey and say that it is overconstrained.  I can only get it to not be overconstrained by deleting the offset curve constraint.
What's going on here?  Any way to fix it?  I hate not having constraints tied to these curves.
Re: Offset curve always overdimensioned
Hi, Dobie
please try resetting your
  • Inferred Constraints and Dimensions dialog, click OK
  • Offset Curve dialog
Does the problem still persist?
