On Content Help not functioning from the Siemens site
We use the Siemens site for our on content help because we felt that it would be the most current.
We find that it does not work for alot of commands.
This was converted into PR 9049121 but nothing is being done by GTAC.
It works for some commands but not for most
Is anyone else having this issue?
NX11.0.2.7 MP5 Windows 10 Nvidia P5000 382.59
Victor Cohen Engineering manager American Tool & Mold NX11.0.2.7 MP5 Windows10 Nvidia Quadro P5000
10 REPLIES 10
Re: On Content Help not functioning from the Siemens site
Siemens Genius Siemens Genius
Siemens Genius
I closed this PR as by the time it was assigned to me for review your customer data regarding which commands weren't working was no longer available which I described in the Final Response Field of the PR . I tested various design commands using NX11.0.2 and didn't find any issues.
I haven't seen any other similar issues reported by other users of the site.
If you could share a list of some of the commands not working properly for you from the site I can retest and see if I can duplicate the problem.
thanks,
NX Design Apps Documentation & Courseware Manager
I have the same issue with one customer. When I open the online documentation separately it works without any problems, but when the same site is added as the UGII_UGDOC_BASE variable and F1 is pressed for a command, the same error window pops up.
on_context.jpgHello Gregg, thank you for the attention.
I am not sure what you mean by
"customer data regarding which commands weren't working was no longer available"
I thought I had my VAR list them but I guess not.
I have listed some of the commands that are not working below.
There are more but these are pretty representative.
We have this line in our eng_ugii_env.dat that we use to start NX11;
UGII_UGDOC_BASE=https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help/#uid:index
Let me know if you see something similar.
Thank you,
Vic
Create Sketch
Message: Content not found: 'index/tdoc/nx/11/nx_help/#goto:sketcher:sk_create_reattach_opts' (en_US/nx/11/nx_help)
Path: https://docs.plm.automation.siemens.com/tdoc//document
Timestamp: 2018-05-09 07:13:45
Datum Plane
Message: Content not found: 'index/tdoc/nx/11/nx_help/#goto:modeling:feat_datum_plane_dialg' (en_US/nx/11/nx_help)
Timestamp: 2018-05-09 07:14:40
Extrude
Message: Content not found: 'index/tdoc/nx/11/nx_help/#goto:modeling:feat_extrude_dialog' (en_US/nx/11/nx_help)
Timestamp: 2018-05-09 07:17:17
Hole
Message: Content not found: 'index/tdoc/nx/11/nx_help/#goto:modeling:adv_hole_feat_ov' (en_US/nx/11/nx_help)
Timestamp: 2018-05-09 07:18:01
Siemens Genius
Hi Vic:
Just looking at those URLs you sent you receive when you choose context sensitive help (https://docs.plm.automation.siemens.com/tdoc//document) I can tell something is amiss with your settings.
I just tested each of those commands and they worked for me.
Here’s what I found, hopefully you can figure out which variables are set incorrectly in your system by comparing what my system is using out of the box below:
My log file shows I am running NX 11.0.2.7.
My help environment variables are set as follows:
UGII_UGDOC_BASE                 https://docs.plm.automation.siemens.com
UGII_UGDOC_API_BASE             https://docs.plm.automation.siemens.com
UGII_DOC_VERSION                 11.0.2
UGII_HELP_RELEASE_NOTES         https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/release_notes/#uid:index
UGII_HELP_WHATS_NEW             https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help/#uid:index_whatsnew
UGII_CSHELP_DOCS                 https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help
UGII_CSHELP_API_DOCS             https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_api
UGII_CSHELP_DEFAULTS_DOCS       https://docs.plm.automation.siemens.com/data_services/resources/nx/11.0.2/nx_help/common/en_US/graph...
UGII_CSHELP_FUSION_DOCS         https://docs.plm.automation.siemens.com/data_services/resources/nx/11.0.2/nx_api/common/en_US/graphi...
When I tested each command, below I have listed the correct URL you should have received to make context sensitive help via F1 work (see GM: Correct URL should be):
Create Sketch
Message: Content not found: 'index/tdoc/nx/11/nx_help/#goto:sketcher:sk_create_reattach_opts' (en_US/nx/11/nx_help) Path: https://docs.plm.automation.siemens.com/tdoc//document Timestamp: 2018-05-09 07:13:45
GM: Correct URL should be:  https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help/#goto:sketcher:sk_create_reattach_opt...
Datum Plane
Message: Content not found: 'index/tdoc/nx/11/nx_help/#goto:modeling:feat_datum_plane_dialg' (en_US/nx/11/nx_help) Path: https://docs.plm.automation.siemens.com/tdoc//document Timestamp: 2018-05-09 07:14:40
GM: Correct URL should be  https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help/#goto:modeling:feat_datum_plane_dialg
Extrude
Message: Content not found: 'index/tdoc/nx/11/nx_help/#goto:modeling:feat_extrude_dialog' (en_US/nx/11/nx_help) Path: https://docs.plm.automation.siemens.com/tdoc//document Timestamp: 2018-05-09 07:17:17
GM: Correct URL should be   https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help/#goto:modeling:feat_extrude_dialog
Hole
Message: Content not found: 'index/tdoc/nx/11/nx_help/#goto:modeling:adv_hole_feat_ov' (en_US/nx/11/nx_help) Path: https://docs.plm.automation.siemens.com/tdoc//document Timestamp: 2018-05-09 07:18:01
GM: Correct URL should be  https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help/#goto:modeling:adv_hole_feat_ov
Hi @vcohen,
You have:
Change the url to:
and you should be fine.
Regards, Ben
NX (v17 - 1872) | Teamcenter (9 - 12)
It looks like you have alot of additional environment variables that I do not.
The URL you posted for Hole feature
The URL i get when I select help on context for Hole Feature
https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help/#uid:index/tdoc/nx/11/nx_help/#goto:modeling:adv_hole_feat_ov
Thank you BenBroad!
That was it.
I can't take the credit.  @Gregg_Makepeace provided the solution - I just condensed it Smiley Wink
Ben
Thank you Gregg.
I got intimidated by the number of environment variables.
I should have just looked at your first line.
