Ordinate Dimension
Dear all
Hello every body . I am using NX10.0.2 MP3  .  Now I give dimension of part ( see attach file cuurent.jpg)  and I want to get dimension same in attach file ( target.jpg) How to get it ?
thank you
Re: Ordinate Dimension
When in the Ordinate Dimension dialog, select Settings -> Ordinate and toggle OFF the 'Show Dimension Line' option.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
What if the line between arrows is already toggled off?
Julie VM
It works as per suggestion from @JohnRBakerSmiley Happy
Only thing is that, if you change the setting by selecting only one ordinate dimension then it will apply same to other ordiante dimensions also.
Ganesh
