OrientXpress can't be moved away
Sometimes the OrientXpress tool can't be moved away. It's very annoying.
Is there a fix? Thanks!
Re: OrientXpress can't be moved away
Hi @surfactant,
You should just be able to grab a part of the Orient Express and drag it out of the way.  If that doesn't work, scrolling your middle mouse wheel slightly (if you have one) to zoom in might be enough that the Orient Express moves out of the region you're trying to focus in.  If you're able to reproduce the problem at will, please report it to GTAC.
Regards, Ben
Hi @BenBroad   In most time it can be dragged away, but sometimes it never moves no matter how you drag it. I don't know exactly when the issue would come up. Thanks!
