PDW adding standardparts to subfolders
Hello everybody,
I need to add standard parts to subassembly in PDW.  Which part I should  edit? Do you know which atribute should I add where??
I hope u have any idea how to help me.
best regards
lukipap
4 REPLIES 4
Re: PDW adding standardparts to subfolders
You need to download the PDW library from GTAC and install it. It is a separate installation and does not come with standard NX installtion. Same with Mold Wizard.
Hope I got your question right!
Amit
I have already download this library grom GTAC. I mean how I can make template, where the standart parts go automaticly to subassembly which I want.
Thanks for reply.
best regards
Select the Parent Part; As it is requesting.
Your Standard Parts will be under that component.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
but I want to make it automaticlly not manually after I add some strndard parts.
best regards
