PMI Dimensions in JT Preview?
For TC-NX Integration
I have part with PMI dimensions created in Modeling application. When I save the part (also JT) and check the JT preview in Teamcenter, JT preview shows only 3D geomtery without PMI. Is this default expected behaviour or Is it possible to view geomtery with PMI in JT preview?
I checked this in native NX by saving the part with JT file and opened JT file in NX then it was showing the PMI also.
Ganesh
Re: PMI Dimensions in JT Preview?
Turn on your PMI filters.  You will have to find the "filters" in your teamcenter vis and toggle on/off your filters for your PMI to show up.  You will need to turn on your 3D PMI toolbar.  Then toggle the PMI icon.  Then go to PMI query filters.  Toggle this on and off.  Then your PMI should show up.  See attached screen shot.  I hope this helps.
Thank you for the solution. Now I know how to do it. Smiley Happy
Ganesh
In addition make sure the PMI toolbar is turned on and PMI is turned on to get the filters to work.
TCwithPMI.pngPMI in Teamcenter
Scott
@ScottFelber: Thank you for the tip! Smiley Happy
Ganesh
