PMI Section View
Hi everyone,
I need to make a multi plane Section View so using this link https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=section%20view%20lega... I got to use the legacy Section View from PMI tab. It allows you to make a Section using curves, that would be the solution. The thing is that when I active the section view that I create with this command, the part remains sectioned and I cant turn it off. Is there a way to do this? Does it work like the Clip Section from the View tab?
thanks
Re: PMI Section View
I'm not sure what the concern is...you know that a unique model view is created when you use a PMI section view command (the current command or the legacy command), right? It's a permanent view that will aways show the model as sectioned. Just switch to another model view to see the entire model.
"Just switch to another model view to see the entire model."
That's the thing I didn't know I have to do. Thanks!!
