PMI in a upper assembly level.
Hi.
I created a PMI in a part component, how can I see this PMI in a upper assembly level?
Thank you.
Re: PMI in a upper assembly level.
Hi @Thais,
Open the Part Navigator and expand the Model Views node - note the PMI Assembly Filters folder.  Right click this folder and choose Add Filter and choose which ever option is suitable to you.  I selected "Display All" and then set "Components to Use" to All Components".  You then right click your new filter and choose "Apply to View" and check which views you wish to see the PMI.
NX 11 Documentation: PMI Assembly Filters
Regards, Ben
