PTS Clone Rules
Hello guys,
I'm wondering if anyone could help us with following situation:
We have got an assembly prepared with an PTS template for easy re-use when dragging in from the ReUse library.
In the PTS template of the assembly, we have got the option "Enable Copy/Clone on drag and drop" set to "true".
Anyway we want specific components of that assembly to be cloned and other should "retain" the same, when dragging in and cloning the assembly.
We have tried to use the part attribute PTS_CLONE set to the value "false" at those components, which should retain.
But anyway the assembly and all components (except the family member parts) get cloned during the drag in from the ReUse library.
Does anyone have got an idea or solution to that problem?
Best regards,
Dominik
