Pan Tilt Vibration Stability
Hi There,
I need to design a Pan and Tilt control System using a mechanical piston\Pneumatics Piston or any other mechanical solution. This system is Large. Do you have any material to read about it? maybe a guide taking into account all the considerations on typical systems similar to this.
