Part Family Error
Hi there,
I'm having some troubles in member creation from a spreedsheet part family.
Re: Part Family Error
did you check first on your template part if the changes you made in the spreadsheet is also working in your model?
When i create a part family part, i first test my model if the expressions changes are working on the model.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
I didn't. But the only way that i found for solve was export my solids as parasolid and create a new file.
Maybe my file was corrupted.
