Part Family
I am trying to create a Part Family. I either am doing something wrong or possibly my version of Excel isn't compatible. I have attached a part file. I would appreciate it if someone could look at it and give me some suggestions.
Re: Part Family
@SR what problem are you facing exactly? Could you please describe it or record the video of the same and upload here.
Ganesh
Re: Part Family
I tried to add a video. for some reason I am getting an error, maybe its to long and its timming out. can I send it to you email? I tried to show that when I am done with the Part Family function that I hit OK and then I try the Spreadsheet function and it comes up blank. Then I go back into the Family Table function and hit Edit Spread sheet, thats where I get those errors. So then I go back into the Spreadsheet function and add everything manually, but it still doesnt work. Instead of having you watch me manually edit the spread sheet I pulled up a part that already had the spreadsheet manually done.
Re: Part Family
I made several attempts at different sized videos but I just can't get one to upload. So here is the part file. I go to Family Table function and add the collumns. I hit ok and then go into Spreadsheet function, but it comes up blank. So I go back into Family Table function and try EDIT spreadsheet. It also comes up blank. I wait for a long time and nothing happens. Then I move the mouse off to the side of spreadsheet and it closes. Then I get error messages. Then I try going back into the Spreadsheet function and fill out the spreadsheet manually. It still didn't work.
Re: Part Family
Unable to play video. Please try again later.
(view in My Videos)
Success, I went to a different wifi network and was able to load the video.
Re: Part Family
(view in My Videos)
This one is for backup, I wasn't sure the last one uploaded
Re: Part Family
(view in My Videos)
last try
Re: Part Family
Unable to view videos uploaded by you.
You can attach the error snaps to the post here.
To have a clear understanding, take a look at this youtube video Part Family.
Ganesh
Re: Part Family
What EXACT versions of NX (including MR and MP) and EXCEL are you trying to use?
Re: Part Family
I realize NX Ver 10.0 isn't enough. Where do I find the Info you want. See attached for Excel.
