Part Mass and Surface area on Drawing
Hello All,
I am trying to get the part mass and surface area on the drawing template.
To acheive this, I created a custom attribute in the seed part called My_mass and linked it to the NX_Mass attribute.
Unfortunately, the value does not change when a end user created a new part using this seed part.
Refer to attached video for details.
Can anyone point me in the right direction for achieving this?
Rushi
Re: Part Mass and Surface area on Drawing
I jsut went thru this a few months ago, and it is frustrating.  Have you tried adding your new My_Mass to the attribute template?  As I recall, I had to to that, for the new attributes to hang around, after deleting the dummy body.
-Dave
Hello Dave,
I have tried both ways, creating the attribute from File Properties and from the attribute template.
Somehow, the expression linking the NX_Mass to My_Mass disappears.
Is there any setting in the template part to save expressions/formula even if they are broken?
Rushi
This thread may have some insight:
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/Populating-title-block-with-Material...
-Dave
