Part families can not be updated
When go into Part Family tool, I got a alert message about changed attributes
Could someone advise where to find and how to use Refresh Required Attributes  tool.
So later I am not able to update family parts. It says:
"Updating member parts in family...
Member in row no 10 is invalid for update."
The same for every row.
Maybe it is somehow connected with changed attributes.
Re: Part families can not be updated
Hi @MTV,
This appears to be an issue (PR 8341269) that was recently resolved in NX10.0.3 mp17.   Are you able to download and install maintenance release NX10.0.3 and then maintenance pack NX10.0.3 mp17 to verify?
Regards, Ben
Hi @BenBroad,
This is the version we have. Is it still being outdated?
Taras
You have latest MR for NX 10. You need to install MP17 as mentioned by Ben. After MP17 installtion, check if problem is reproducible.
Ganesh
