Part list: PC NO= [...] when <W$=@CALLOUT> ?
Hello
Why some parts have [...] as PC NO and when I try to insert manually <W$=@CALLOUT> it turns back to [...] ?
Re: Part list: PC NO= [...] when <W$=@CALLOUT> ?
what is the callout attribute in the properties of that part?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
The […] in the Item field indicates that more than 1 components ‘Name’
share the exact same value, but the ‘CALLOUT’ attribute are set to
different values.
Use the "Key Field" checkbox in the column's settings to identify distinct values:
(view in My Videos)
Regards, Ben
Ok "Key Field"-check box made them appear.
This NX \ TC bug appears still now and then sometimes...
Like 300pcs of same bolts and somehow like 2pcs of the same bolts are seperate and triple dotted.
Like this(Example): NX11+TC11
Pos.   Qty     Name_____
23      300    M8x20 Bolt
(...)      2       M8x20 Bolt
Any reason why this happens ?
Probably the CALLOUT Attribute requires editing to match, I think it comes down to when they were added and the Assembly was saved.
