Part navigator language - different to UGII_LANG
Hi, we have a small problem. In the part navigator tree the language is english but our language setting UGII_LANG is german. Does anyone have an idea? Thanks for your reply! Frank
Re: Part navigator language - different to UGII_LANG
In the customer defaults (Modeling -> general -> general tab) make sure that the "display legacy feature names" is turned off. If it was turned on, note that you will need to restart NX to see the result of the new option.
