Part that has 206 pcs bodies and is difficult to modify ?
Hello
This single one part has bodies(206"pieces").
  • It is a sheet metal part.
  • I'm trying to turn it to Flat-Pattern.(and clean it up to make it more clearer)
  • It was converted from Catia to NX 9 by previous owners.
Re: Part that has 206 pcs bodies and is difficult to modify ?
You can use Optimize face first to reduce redundant faces and geometry.
Then use the top faces only to thicken the sheetand finally use the CONVERT TO SHEET METAL utility.. I am attaching the part file herewith.
Best Regards
Kapil
