Parts List location
Is there a way to pre defined a location to parts list?
3 REPLIES 3
Re: Parts List location
Hi @bauler,
Menu > Preferences > Drafting
Table > Common > Section
Regards, Ben
Never mind. I re-read your question.
I believe the only way is to place an empty parts list on an assembly drawing template or to use some form of automation (perhaps a simple journal?). I'm sure others in the forum will post their solutions.
Regards, Ben
Depending on how deep you want to delve into this...
You could use Menuscript to replace the existing action with a journal that "auto-places" the parts list for you, in the location you want (e.g. depending on sheet size or whatever).
So use click on "normal" button, and everything is "magic".
If you have different types of parts lists, you can pop up a menu for the user to select the type they want.
