Paste Feature and Sew
I am new to NX and i want to know what difference it makes if i use specified new datums or link to original option.
If i want body to be automatically get modified when parent feature is modified then what should i do ?
Also i pasted a sewed body which was solid body (after i sewed competely enclosed surfaces) but after pasting it in new part file became sheet body again what is the reason ?
Although when i deleted pasted sew and sewed back it again in new part file it became solid.
Re: Paste Feature and Sew
You can use 'Extract Geometry' associatively with the type as body. Any changes made to the original body before extract body feature in the PNT will be reflected to the extracted body.
