“Pattern Component” needs time-stamped feature!
I think “Pattern Component” needs time-stamped Reference Feature. Otherwise if the Referenced Feature is cut-out by a secondary subtraction (thru pocket/hole), the patterned components won’t update or respond to a change in Reference Feature location.
Am I missing any settings?
As a work around, could suppress the second thru pocket/hole feature, and let update the pattern and then again unsuppress the second pocket.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
