Pattern Hole Recognitions
I got 3D model comes from other CAD system (STEP format file) with some pattern of hole. That pattern I will use it as a refrence to pattern component in assembly mode.
Is there are feature to recognize pattern from dumb model? I mean same feature recognize feature in SolidEdge ST6. Or any other methode in NX to pattern components based on hole pattern.
Novly
Re: Pattern Hole Recognitions
FYI: https://community.plm.automation.siemens.com/t5/NX-Design-Knowledge-Base/Intelligent-Design-Automati...
In NX modeling, I haven’t seen Feature Recognition capability with a imported model. Also, NX Component Pattern is at a primitive stage compared to other software and I’ve submitted numerous ERs on this subject.
If you still would like to proceed with Pattern Components based on de-parameterized/imported model; I can show you a workaround method.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
