Pattern component - Layout reference
I've used a pattern feature in a part patterned an hole. At more level up, I'm trying to use Pattern component - Layout reference but the command doesn't feel the pattern feature.
Which are constraints, limitation level or assembly load option that permit to use pattern feature in Pattern component - Layout reference ?
Thank you...
Using NX11 and NX1847 serie
RuleDesigner PDM
