Pictorial view
I don't have PMI license and I'd like avoid assembly cut, then it's possible to obtain pictoral view like the image attached ?
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
Re: Pictorial view
Look into using Assembly Cut.  This should get you what you are needing for a 3D View.  But for processing down into a drawing I do not know how that would work.  You may need to add the hatch Manually.
Re: Pictorial view
@cubalibre00 wrote:
You can use 'Break-Out Section View' command.
Ganesh
Re: Pictorial view
@ganesh_Kadole wrote:
@cubalibre00 wrote:
Hi Ganesh,
I've tried to use break-out section, but I'm not able to create a sketch that cut correctly the iso view. Can you veicolate to the right direction ?
Thank you...
RuleDesigner PDM
Re: Pictorial view
@cubalibre00 wrote:
Hi Ganesh,
I have recorded the video for it.
Also have a look at the following video link. May be you can use 'Half Pictorial' command as shown in the video.
https://www.youtube.com/watch?v=AxoZJBEZjWg
Ganesh
