Piping Component File
Builder
Builder
Dear All, In Mechanical Routing application if you enable piping and tubing application, you see Piping component file command that can be used by the Isogen isometric drawing generator. Is there anyway to import pcf files into NX? And how is it possible to install PCF Generation plug-in?
Sina Shojaee
Re: Piping Component File
Hi @Sina
No
..how is it possible to install PCF Generation plug-in?
It is installed by default as part of the libroute_plugins.dll in the %UGII_BASE_DIR%\UGROUTE_MECH\plugins directory and enabled in the application view file.  For example, open the %UGII_BASE_DIR%\UGROUTE_MECH\appview\ugroute_mech_inch.xml in a text editor and search for "ROUTE_PCF_GENERATION" and "ROUTE_PCF_EXPORTER".
Regards, Ben
