Placing a basic intersection symbol on a view ?
Hello ( Drafting Sheet metal )
How to place a basic intersection symbol if the lines are wavy / irregular ? NX can't do it because NX wants straight lines.
  • I can easily place intersection symbols if lines are straight.
  • In this projected view the lines look straight but NX still says "Drafting Ellipse" and I can't place the intersection symbol.
Re: Placing a basic intersection symbol on a view ?
Back in the 'old days' I would have expanded into the view and used Simplify Curve on these edges. Now that you can Sketch in the View I'd be inclined to suggest that, as the curves would remain associative. What about a section view?
Regards, Ben
A workaround that I use with 'quite straight' curves is to use 2D centerline By points.
