Please explain NX 10 Constraint behavior (new)
Hello, I'm working in an assembly and noticed that I have an "inconsistently constrained symbol" next to a component in the Contraint Navigator.  However, when I expand out the constraints for that component, none of the constraints show as "inconsistently constrained".  I went to the assembly navigator and expanded out the constraints and didn't find any problems there, either.  Why would this type of behavior be occurring?  Seems like dealing with constraints often requires a good amount of detective work.  Might be good for people that like puzzles...  Smiley Surprised)    Thanks
5 REPLIES 5
Re: Please explain NX 10 Constraint behavior (new)
I know this is probobaly not much for you as an answer but may be it will be of some help.
https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help/#uid:id1267739
Best Regards
Kapil
@kapilsharma, your link gives me a 404 not found error.
I also get the same error.  Looks like the link is directing for NX 11.  We're stuck on NX 10.
Sorry i have no idea why the link does not work...for me it is fine..here is one for NX10 doc
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:id1267738 ....i feel there is more information given in the NX11 help thread than the NX10 link.
Kapil
Hi @kapilsharma,
You had a space on the end of your URL which has been corrected.
Regards, Ben
