Please help me! drawing 2D is hided, can not show.
Builder
Builder
Hi
Im new user. i using Nx 9
I design 3D assembly, after I design 2D drawing  in drafting of Nx.I saved and worked is normal. after I Saved the same.  But today i dont know why when I Start again file Nx, it is  error 2D drawing. I cant show it. It is occur once, i delete all 2D drawing and try again.
plesae watch my video. Who can help me!
https://www.youtube.com/watch?v=b21FHZi2-fU
Re: Please help me! drawing 2D is hided, can not show.
@ledungutc wrote:
Hi
First, why you don't have created the drafting in master model approach ?
Master model approach is the drafting separated by the 3D model.
Second, are you sure that ALL component are visible in the assembly, not only the first level ?
tray to do an update manually or reset the view.
Thank you...
Using NX 11 / RuleDesigner PDM
Builder
Builder
Dear cubalibre00
I dont undstand whats Master Model approach. Can you describe or help me by Skype ?
thanks you very much.
This is the NX basic....
English is not my language, maybe an english man can have time to explain basic NX rules.
Thank you...
Builder
Builder
Hi
English is not my language too. Smiley Sad . I fidgety when use Nx drafting.
thanks you for your support.
Have you tried doing a show all?  Try going to utility and show all??
The most common causes are due to show/hide states or layer settings.
1) You have red checkboxes in the Assembly Navigator, so your components are in a show state.  I don't believe you've inverted show & hide as you can see your dimensions.  However, a quick test in Drafting is to select "Edit > Show & Hide > Invert Shown and Hidden" (or Ctrl + Shift + B".  The dimensions will disappear but you might now see geometry in the views.  Repeat the Invert Shown and Hidden command to return back to the original state to see your dimensions.
If your components did not appear, then you need to look at layer settings in the next step.
If your components did appear in the views you will have to show that geometry:
In Modeling, select "Edit > Show & Hide > Show All" (or select Ctrl + Shift + U).
Return to Drafting and see if the geometry now displays in the views.
2) In Modeling (or Drafting) check which layers contain the components:
Format > Layer Settings
Uncheck Category Display
Select components from the Assembly Navigator and make a note of which layers are highlighted on the Layer Settings dialog.
In Drafting, check to see if those layers are visible in the views on the sheets:
Format > Visible in View > Select a view
Scroll down the list of layers and see if the layer numbers containing the components are visible.  If they do not have a visible status, make them visible and choose OK.
Let us know what you find.
Builder
Builder
Dear BenBroad
but it is not easy. I see hide geometry but i cant show it on my drawing. I can't control them hide and show . Can you help me by Spkye or Teamview. Smiley Sad
https://www.youtube.com/my_videos?o=U
Help me.
You should call your nearest GTAC office - see attachment for a list of global phone numbers.
Builder
Builder
Thanks you very much
but Im sorry, I live in VietNam and english is not my languge. Smiley Sad
