Plug/Slot weld problem
I'm not able to plug holes via weld application. Only if I promote components. Solutions ?
Thank you...
Using NX 11 / RuleDesigner PDM
Re: Plug/Slot weld problem
Hi Cubalibre,
I am on NX11.0.1 and it is working fine for me without PROMOTION.
Is this what you required?
Best Regards
Kapil
Hi @kapilsharma,
the switch on NX 11.0.2 will be on second week of agoust. Now I'm on NX 10.0.3 MP 17.
Can you provide with a video so I try to replicate the workflow on NX 10 ?
Thank you...
Hi Cubalibre,
I guess you are correct (will wait for other replies also) . I just checked it in NX10.0.3.5 and it does not work as in NX11.
Best Regards
Kapil
The problem is confirmed in NX 10, resolved in NX 11.
Thank you...
