Predict Next command not availabe in NX 1863
Predict Next command is not avialble in Interface in left tab.
1. Predict next command is activated in customer defaults.
2. Tried Custom settings in NX
@sunilasone
6 REPLIES 6
Re: Predict Next command not availabe in NX 1863
Hi @SunilAmberkarS
It requires a separate license.
As mentioned by @PatMcManus  in the comments of this blog article, It is an add-on product (NX30179 - NX Command Prediction).
Hi Sunil,
As you can see in command description itself that "This command is not available" meaning this is not available in this NX version or the required license is not available.
Do you have any doc link that talks about this functionality like What's New?
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
Can we add this command as add-on to our present licences
Yes if you are using NX version of 1847 series.
Hey,
predected as might be licence issue. Thanks for confirming. can you share more about adaptive UI
@sunilasone
