Problem Importing .cgm Files into NX10
Builder
Builder
Running NX10.0.2.6 -
I can export a .cgm file from NX10 - Drafting or Modeling. I CANNOT import that same file BACK into NX10.
I can place it into Adobe Illustrator and import it into NX9 without issue. Exporting that same geometry into another cgm file from NX9 and trying to import that second file into NX10 doesn't work either.
The error message is:
Unable to import cgm due to error: File not open
Has anyone else experienced this and/or found a fix for this?
Thanks!
Re: Problem Importing .cgm Files into NX10
fix posted on eng-tips: http://www.eng-tips.com/viewthread.cfm?qid=403401
Anthony Galante, Senior Support Engineer
PhoenxPLM
24 versions of NX installed: NX4 to NX12, plus TC11.2
Builder
Builder
I had not seen your last post before I posted here.
you wouldn't have, I posted that after you created this one.
PhoenxPLM
@Vikingbro totally off topic, but what's the golf industry like at the moment? How do you find NX for club design?
I did 10 years on NX as a golf club designer for an Australian based titanium club supplier.
PhoenxPLM
Builder
Builder
Let me put it this way, it sure beats my last job in aerospace. Most of the products I work on now are organic shapes. Lots of different ways to test my NX skills.
Turbine engine work was much more rigid.
