Problem measuring angle
My measure angle command brings up the simple angle display.  In other words, I can't get the xy xz zy projected angles to display in the information window.  I've tried resetting my user to the preset NX choices... I've used command finder and i've checked the customized settings.  No matter how I launch measure angle... it instead gives me the simple angle command.  Help please.
WIN 7 64-BIT
NX9.0.3.4
Re: Problem measuring angle
Select the gear icon on the top left of the "Simple Angle" dialog and choose "Measure Angle (More)".
Regards, Ben
wow, Thanks.
WIN 7 64-BIT
NX9.0.3.4
Hello @QME-NX,
I believe this is a known issue, and has been fixed in NX 9.0.3 MP4 and later (and NX 10.0.1). Looking at your signature, it looks like you are missing the Maintenance Pack. Installing that should make life a lot easier.
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
