Problem modifying or creating a section (Pre-NX 8.5) drawing imported from I-deas
I have a drawing and assembly that were both imported from I-deas.  The migration to NX created some problems on the drawing.  Whenever I try to do anything to the section views - in this case I want to hide some extra geometry - I get the error message: "Exact (Pre-NX 8.5) Section View, 4-Section A-A, did not update."  I also deleted the section view and then tried to re-create it and I get the same message.  Even when I try to create any section view, the message appears.  Does anyone have a solution?  Thanks.
Re: Problem modifying or creating a section (Pre-NX 8.5) drawing imported from I-deas
can you send a screenshot of this message.
Sometimes the section view has problems with intersection bodies/faces
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
