Problem - start new & mause right click in background
Solution Partner Innovator Solution Partner Innovator
Hi
I use NX10 Version.
# PC Infomation
1) OS : Window7 - 64BIT
2) Version : NX10
I try NX Start new.
Problem is loading time. It takes about 5 minutes.
And problems occur when you right-click in the background.
NX down when it is try.
The cause is unknown. Please help me.
Re: Problem - start new & mause right click in background
Builder
Builder
Hello kimies_saida
are you using NX 10 on new sytem!!!!!!!!!!!!!
if not
than describe your pc configuration with details like ram ,graphics ,etc
Warm Regards
Thomas Roman
Machine Designer
Hello @kimies_saida,
Where are you from? as when i look at you path, where you are saving the part, it contains real strange characters. This does not look to be right. So what are your system settings.
But I would Contact GTAC, so we can have a better look. Provide the Syslog files, so we can investigate this issue.
Easiest way is to go to "File --> Help --> Generate Support logs for IR/PR" and press Collect the logs.
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
