Re: Problem with hole callout
Thats not nice. NX comes at a premium price, but it has so many silly flops, that its embarrassing. Its powerfull, it has various tools, but at the same time it can't even display dimension properly...2018-09-12_09h27_48.png
Hi @dziubelis - it works for me (NX 12.0.2):
Maybe upload your part or contact GTAC to see why yours isn't working?
Regards, Ben
NX (v17 - 1872) | Teamcenter (9 - 12)
How did you model the hole?
as a countersunk hole?
or a plain hole with a chamfer?
 or ?
 or ?
Screw Clearance Hole using Form: Countersunk.
NX 12 part file attached.
Ben - I meant the original poster ;-)
Ken, I did wonder, but I should have supplied my part anyway.
Via Feature, as a Screw Clearance Hole. But I am on NX 11.0.2.7.
BTW does it generate Relief info on NX12+? Cause that hole also has Relief, unfortunatly Hole Callout ignores that completely.
HI i have aproblems with hole callout when i made a hole that intersect with other and used hole callout
i don´t can especified the deep if one hole finish inside de other hole
