Problem with mirror assembly
Hi everyone!
I did mirror assembly associative and non associative.  Nx made mirrors but I have diferences of dimenssions, The axis of holes are not Collinear. Pls check the attachment. I will be glad if someone is able to gelp me.
Re: Problem with mirror assembly
Axis of Holes? Holes will belong to the component in the assembly. Creating the associative/non-associative mirror copy will not have any impact on the position of the holes. There may be something else causing this problem.
Ganesh Kadole
