Problem with opening files from newe vrsion of SolidEdge in NX 11
Hi everyone,
I try to open files from ST10 in NX 11 but there error appear:
the following files could not be loaded, causing this open to fail...
th part file is from a newer version of the application than the one supported by NX
Someon is able to help me ??
Re: Problem with opening files from newe vrsion of SolidEdge in NX 11
Export in parasolid.
Hi @lukipap,
Is it NX 11/11.0.1/11.0.2, because similar case was reported for ST9. You can check it
Can not open SE9 part in NX11
Ganesh
Hello @lukipap,
@GaneshKadole, is close... But you are talking about ST10 not 9. But the solutions is very similar. If you go to our download, you can also find a file you can use for st10 files. plmxmlAdapterSE70.dll.
You can find it in here:
https://download.industrysoftware.automation.siemens.com/solid_edge/ST10/plmxml/
Hope this helps.
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
Also have a look at this article:
http://solutions.industrysoftware.automation.siemens.com/view.php?si=001-8996891
Dennis de Brouwer
