Program alarm NX 9.0.3 MP2
Today I am install NX 9.0.3 MP02  . When I  open program NX  it has messeage from window ( picture in attach file )  . What is the problem ?
thank you
3 REPLIES 3
Re: Program alarm NX 9.0.3 MP2
I ran this by our experts.  The following was suggested:
This could happen of the installer was not part of the local admin group. The installer could have been a member of the ‘network admin group’ and not a member of the ’local admin group’.
Suggestions:
  • Reinstall and make sure the installer is a member of the ‘local admin group’
or
  • Uncheck the box ‘Always ask before opening this file’ and the select ‘Run’
We have the same problem on every workstation and that's in NX8.5
We tried different permission and Admin levels and it does not help.
Unchecking the box does not do anything.  Shows up every time you start NX.
Jerry
NX8.5.2.3 Win64bit
I do this:
Start Internet Explorer
go in internet options
select tab "security" and choose "local intranet" and then "Sites"
click on advanced
below "Add site to area" write your "domainname.domainextension" (I write bimal.com)
Click close.
To check if all goes ok click again on advance button. You should read some what similar to file://*.domainname.domainextension
This works for me.
Bye
Fabio
I use NX10 with Gerrit Koelewijn configuration utilities. Thanks to Rob Cohon.
