Progressive Die Design documentation.
Hello everybody,
Is there any kind of documentation to learn the Progressive Die Design application? I mean, not only the online documentation that comes with NX, but some training course documentation.
Frank.
3 REPLIES 3
Re: Progressive Die Design documentation.
Hi Frank,
I suppose you require  training content for PDW. I am not sure if we have this available online.
You can get in touch with your local Siemens contact for the same. He/She might be able to help you with this.
Best Regards
Kapil Sharma
Yes. we attended Simens NX in class training three years ago and received training material with it.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
It looks like the Siemens on-line "Learning Advantage" has some courses.
Start here:
https://training.plm.automation.siemens.com/index.cfm
I would assume they will want some $$
