Quicker way to update NX assembly structure?
Hello all,
Say I have an assembly open in NX Manager, a fellow engineer makes some changes to a sub assembly within that assembly.  Does anyone know of a quick way to update the assembly structure without having to close and re-open the entire assembly?
Currently, we select Menu from the ribbon, > File > Close > Close and reopen all modified parts.
As i'm sure all of you know, if you have a large assembly open, this can be very time consuming.
Using NX 9/TC 10
Any input is appreciated. Looking forward to some responses.
Thanks in adnvance,
Jake
Re: Quicker way to update NX assembly structure?
You could run the HD3D report Modified in Teamcenter then add the reporting columns to the ANT and use that to selectively re-open the relevant parts...
