RE: Exporting prt file to dwg file
 At One of my clients place near export as I'm not able to see 2D Tab. Fot that do we need any author license for that.can anyone help me with this.AUTOCAD WIZARD.JPG
Re: RE: Exporting prt file to dwg file
Check to see if you have a 2DExchange license.
Hi @RonY,
   thanks for the help..license is not there
