Re Open Modified Assembly?
If I modified my assembly is there a feature to reopen my assembly to the last saved iteration?
I know you can close and reopen, but I want to know if there is another way.
If I right click on a modified component on the assembly module, I can reopen that component to the last saved version. But I'm not sure if there is something similar I can do to the assembly to save some time.
Thanks.
Re: Re Open Modified Assembly?
File > Close > 'Close and Reopen Selected Parts'
Here you can select a single component that has been modified and reopen or use 'Reopen All Modified Parts' from the same window.
File > Close > 'Close and Reopen All Modified Parts'
Ganesh
