Reading expressions from within Teamcenter
I frequently use "import expressions from file" function that exists in the expressions menu, to update the expressions in a model through importing a file with a .exp extension. This file seems that it can only be imported from the local drive.
I would like to place this .exp file in teamcenter and get my model to read expressions from within teamcenter, like reading expressions from a spreadsheet in teamcenter with ug_excel_read() function.
Is that possible?
Re: Reading expressions from within Teamcenter
Hi @Onur1,
Unfortunately not.
We have an enhancement request in our system (ER 5793462) asking for the ability to access Teamcenter datasets using "Import Expressions From File".
Regards, Ben
