Realize Shape on any body?
Honored Contributor
Honored Contributor
I've seen demos of ANSA morphing any solid/sheet body you import into it, which looks similar to what Realize Shape does, except the Realize Shape demos always start with a primitive.
My question, are you restricted to a primitive as a starting point?  what we would like is to use Realize Shape to make variations of existing parts for CAE/CFD testing.
-Dave
NX 11 testing NX1847+ | Teamcenter 11 | Windows 10
4 REPLIES 4
Re: Realize Shape on any body?
Dave, I quickly created two sheet bodies and then start NX Realize Shape. I need to extract the edges to polylines in NX Realize Shape. I created a new NX Realize Shape between them using loft and then did a transfrom on this flat surface. I have attached the file in NX 11 that I created.
Scott
Honored Contributor
Honored Contributor
Thanks Scott.  Presently I lack a license for Realize, but looking at the file I get the basic idea.  The nice thing about ANSA, is that it will take any existing solid body, say an entire exhaust system, and within minutes you can morph it into a different shape, with no recreation of the body, just pulling on nodes.
-Dave
Hi Dave,
I am attaching a short video herewith. Do you have something simmilar in mind? I am modifying the actual /imported body (didn't create any primitive as such).
(view in My Videos)
Honored Contributor
Honored Contributor
This is the demo one of our guys put together to show our sales/support rep.  It's a bit long, but goes thru the process from the import into ANSA, to the morphed part.
(view in My Videos)
-Dave
